1. Cable manufacturer provide tolerance on the dimension of the cable outer diameter (OD) and inner sheath diameter(ID).
2. Cable Gland manufacture provide tolerance for the cable gland diameter under armour (ID) and the outer sheath (OD)
Does Cable ID & OD tolerance should always be within the tolerance band of Cable gland ID & OD?
Sometimes the tolerance band does not match. In those situations, how should we select the cable gland? for example, in the below table, the cable ID and OD tolerance is not within the tolerance band of the cable gland.
Should the ID tolerance of the cable gland be selected such that it excess the maximum cable inner sheath diameter (or) be less than it
| ID Tolerance (mm) |
| OD Tolerance (mm) |
| Cable |
| 25-30 |
| 30.3-36.3 |
| Cable Gland (M40) |
| 22-27 |
| 35.0-44.2 |
