Sparkingchip:
Is this switching on the stairs?
When was the house built?
Is all the lighting circuit wired in insulated singles?
Are there CPC earth wires at every fitting?
Do the metal back boxes have nylon fixing lugs to retain the switch plate fixing screws?
Is there more than one lighting circuit, if do are they RCD protected by more than one RCD?
Andy Betteridge
The switch is for the downstairs hall, currently switched from kitchen and bottom of stairs they want an additional switch at the front door.
Building is old, don’t know how old.
No, the house is wired in Red and black twin and earth , the insulated single is only the one fitting I have seen it at.
The cpc is continuous throughout the property.
The property is dual rcd with lighting on the same side
Clint:
Legh Richardson:
I'm pretty sure there will be a Joint Box (JB) hiding somewhere under the floor or in the walls. We used a 25kHz live tracker on several occasions to chase around the installations to find all the hidden JBs.
Legh
What is this 25kHz you speak of? Also how do they work?
