Clint:
So you say the L1 and L2 are the strippers?
The only thing is I can’t seem to locate where the permanent live is fed?
what I meant by 3 T&E, is there is 3 Twin and earth cables up at the light fitting. They all connect into the permanent live and neutrals so I assume they just go off to other fittings.
Chris Pearson:
Clint:
You must have the same auto-correct dictionary that I have. ?The only thing is I can’t seem to locate where the permanent live is fed?
So loop in and two loops out? Are you sure that the permanent live to the switch isn't hiding in there somewhere?
In any event, to make things clearer, the intermediate switch will flip the two strappers. If the cable has any slack, you may get away with one JB, otherwise you will need two. It is just a matter of taking the two strappers down (or up) to the switch and back again. Alternatively, if the cable is accessible, you undo the red/black at one end and bring it down to the new switch. You then insert a new piece of the cable from the new switch to the old one.
Don't forget your brown sleeving and the new and old colours notice! ?
And what about that CPC? Clearly there is one in the T&E cables, but from the sound of it, the switches are unearthed.
Lol I didn’t even realise the auto correct ?
Im pretty sure there wasn’t 2 single core, cables at the light fitting tho, just the one which was connected to the lamp live.
Now am I right to believe that one of the switches I will have to have connected L1 and L2 as permanent live and switched live ?Apologies if this comes across rookie!
sleeving is always used by me ? also cpcs were at switches
Legh Richardson:
I'm pretty sure there will be a Joint Box (JB) hiding somewhere under the floor or in the walls. We used a 25kHz live tracker on several occasions to chase around the installations to find all the hidden JBs.
Legh
What is this 25kHz you speak of? Also how do they work?
