Lightning conductor for ametuer radio antenna mast - electrician says regular PVC sheated yellow green wire is ok from mast to earth rod
As per title I am getting a corner of my house setup as a radio shack and wanted to protect it appropriately.
The antenna is made of fibre glass but sits on an aluminium pole that brings the total height to 10m tall (only house in the area).
We have agreed to setup an earth rod below the antenna mast and earth it but the question is - will regular 35mm green/yellow sheated earth be good enough to provide earthing for antenna mast while being exposed to the elements? How long will it last?
Any thoughts on the electrical setup for the radio? We are planning to use the same earth rod and make a TT island for the power socket that feeds the radio unit (as main electrics is PME). The radio will be fed electric connection through an MCB by taking power from the main distribution box protected by a Type 1/2/3 SPD (I have 3 phase 100A supply from DNO) and we will use the earth rod for earth supply.
The radio unit will be powered by a seperate consumer unit which gets it's earth supply from the rod (I might also get a Type 1 SPD in the TT island consumer box).
The antenna and the TT island powering the radio will be linked by a 700A rated earth bar enclosed outside the property in an IP65 enclosure.
Appreciate any thoughts on my setup.
Am I being overkill and do not need a TT island for my radio setup? Will earthing the antenna be sufficient?
  • FaeLLe:
    . . . any further development on that plot of land will need their approval. . .
    . . . if I wanted to rebuild over it I could just serve them notice and proceed to dig out whatever is there (will allow a 60 day time or whatever for rectification). . .
    The DNO have the right to object to any development that may affect their assets. The presence of any DNO assets should have been identified as part of the legal process when you purchased your property. You should have similar plans showing water, sewerage and gas.
    Alan.
