Cable glands - Eaton Vs CMP
EATON cable glands comes with many sealing ranges for the same gland size, Eaton gland selection chart below
Where as CMP glands comes with one sealing range for the same gland size, CMP gland selection chart below
Why do EATON have many sealing ranges for the same gland size, whereas CMP glands have one sealing range? What are the advantages/disadvantages on this?
  • Of the three M25 sizes Eaton offer, the first two look to be cover the same range as the two larger M20 sizes - so I suppose are useful where you have a smaller cable but a larger hole.
    The (only) M25 size from CMP looks to be broadly similar to the largest M25 from Eaton.
    So if you were in the situation of having to put a smaller cable in an M25 hole, with Eaton you could get a gland to fit, with CMP you'd might have to find an additional M25 to M20 adaptor.
    You pays your money and takes your choice.
