DIY Electric fencing - any thoughts?
So we have a fox problem and metal fencing all around the detached house, they come in and drop faeces everywhere and with a little child it is a safety issue really.
Is it possible to make a DIY electric fence (mains powered or through a 12V DC adapter supplied through an IP65 outdoor socket)?
I would look to run a seperate circuit for the outdoor socket for this purpose, but what should it be protected behind on a consumer unit - MCB / RCD / RCBO?
I guess at every instance of electrocution of the fox it would trip the circuit but I could accept a daily of trip protection if required.
Is there any legislation surrounding this?
    So my .22 would work perfect except that I have never seen a single one! They always come when I am sleeping and my grounds on all 4 sides are difficult to get coverage of.
    I would need to install some sort of motion sensors and wake up from sleep to hunt them...
  • OMS:
    . . . I've seen the buggers inside substations that have 8 foot high electric fencing on the inner line - and it bloody hurts to touch that . . .
    Indeed it does. The stock fences are only a kV or so. The substation fences are about 7kV. They are designed to “throw off” anyone who climbs them, as well as giving an alarm back to grid control.
    Alan.
  • When in South Africa and kept Rottweillers as you do, I had a similar problem ... but in keeping dogs in and to stop them burrowing below a slabbed, concrete wall.
    I bought a custom mains transformer, and made an electric fence from thin gauge, galvanised wire on insulated supports; the supports were square, steel, reinforcing rods driven into the ground, and for insulation - plastic tubing slid over the rods, squashed at the top to create an insulated support and stop the tube from sliding down.
    An effective, non lethal solution, ? I expect with elf and safety in the UK you would need warning notices, not that the foxes can read though.
    Jaymack
    Chris Pearson:
    As OMS says, a .22 will do the job nicely. Best if they are suppressed - don't want to upset the neighbours who feed them.
    Use subsonic ammo - the workings will be louder than the round - except for the "thump" of round on target of course
    OMS
    FaeLLe:
    Dishes of dog food would do the trick - they'll be along in no time.
    Personally, I'd leave them alone this time of year and then thin the population out late autumn
    OMS
