Light bulb safety
Hi all
Asking for a friend who needs to change a light bulb in their new home.
The current light bulb in the ceiling pendant is a 40w (28w halogen) bulb but they find it too dim.
Can they safely swap that out for a 60w (42w halogen)?
There's no rating stickers or information of any on the light fitting itself so they don't want to put in a higher rated bulb if it may overheat and cause a fire.
  • Lisa Lisa Lisa, we put bulbs in gardens and we put lamps in lampholders. Go to the naughty corner. LED lamp is the way to go by the way (in a lampholder)
  • Lisa, do not go on the naughty step just yet as you are amongst the probably 99.99999999% of the population who believe the bulb to be the correct term for an electric light bulb. All the english dictionaries I have read (Chambers, OED. etc) describe a lamp as the unit providing illumination as in gas lamp, electric lamp and a bulb as the source of illumination in a lamp, as well as the horticultural definition. It is only amongst electricians that the bulb becomes the lamp and a lamp a lamp holder. ?
  • I use CFLs on the stairwell.  I don't really care about the light quality, and they were being given away a while back, so I have loads of them.  I find 11W perfectly adequate, but I don't really need a brightly lit stairwell.
  • Simon Barker:
    I would want to see what I'm falling on, ?. A stairwell in particular is the place for adequate lumens.
    Jaymack
  • kfh:
    There were lamps before leccy, and they might have been placed in a lamp holder. What they certainly didn't have was a bulb or if you want to be old-fashioned, a globe.
    Don't worry about the naught step, Lisa. I will join you there and we can be naughty together. ?
  • Presumably that sounded alright in your head Chris!
  • Electric lamps or light bulbs, we know what we mean....Incandescence Lamps......
    https://en.wikipedia.org/wiki/Edison_and_Swan_Electric_Light_Company
    Watts in a name anyway?
    https://en.wikipedia.org/wiki/Edison_light_bulb        Z.
  • Very punie ?
  • Lisa Miles:
     might be a sticker visible inside when the lamp is taken out.
    How many engineers does it take to change a light bulb? :)
  • As I remember lighting circuits were designed to take  a maximum of 10 times 100W lamps @240V, fuse rating at 5A.
    Using 6A MCBs @230V nominal Voltage you could increase the number of lamps on the circuit to 12.
    100W tungsten filament lamps = 15-20W LED in light output. You will probably only need 11W LED to provide suitable illumination for a stairwell.These figures are only approximate as the watt rating of LEDs varies somewatt ......
    Legh
    Just to add we still use B22 bayonet cap fittings
