pyro/micc tools
Does anyone know where to get a micc straightening tool from other than auction Sites, cannot seem to find any or other possible options welcome
    Get in touch with the BOD - he's probably still got about 3 dozen still in the original oily paper wrapping
    Everything else but nothing MI I'm afraid OMS as I gave all my MI kit to a contractor 30 years ago. With hindsight I should have kept the "fire resistant" clips!
    What I have found though this last week on "project find the workshop floor" is the extension bar used for spade bits. I obviously couldn't find mine so I bought another, and another..... So far the "tidy up" has found 5 of them..... Also three for the hole saw arbors, not that I use hole saws anymore. Q-max cutters every time now. I can't believe I'd forsaken them after buying a 2" one to fit the extra gauges in my Madadash equipped Minivan aged 19 and forgotten about them for the next 40 years. Wish I kept both the Minivan and the gauges (and my trim figure!).
    As to the OP, I saw the plumber using a proprietary one to straighten out 10 mm coiled copper pipe when installing an oil boiler. Same mechanism as the drawings above but in a moulded grip. Presumably they are made for different diameters so I'd start there, probably Rothen* etc or Monum* etc.........
    BOD
    perspicacious:
    BOD
    Yes thinking about it you are on the right track Mr Bod, there was a brake pipe straightener which was good up to 3/8 / 10 mm that the plumbers used to use for dressing 8mm and 10mm copper pipe, supplied by Sealey I think.
    Rob ?
  • Yes plumbing pipe straightener or one for car brake pipes such as https://www.carbuilder.com/uk/brake-pipe-straightener-tool?gclid=CjwKCAjw95D0BRBFEiwAcO1KDKQ44iLkvAN4dos4v1gLy2XiW_FpDtyXm8vgJO2kokR6DWmFoZRvOxoC-pAQAvD_BwE  available in a variety of sizes
  • WOW, having fixed miles of the stuff... I've never ever seen a tool like that but, I have never needed it either... wow!
    regards...
