Chris Pearson:
It's all in the contract!
Provided that the CU is CE marked, BS certified, and from a reputable source, I find it difficult to see how the electrician could be held liable in the event that the SPD failed to provide the expected level of protection
Thanks for the reply Chris, though i am unsure what contract you refer to?
AJJewsbury:
SPDs only provide protection within certain limits anyway - too close a lightning strike or surges generated within the installation and damage may still occur even if there was nothing wrong with the SPD.
I agree it would be hard to prove anything - I doubt anyone would really know where the source of the particular surge that caused the damage was, or whether the SPD as already expired before the event (user error for not checking the indicator on the SPD). Probably no worse for an electrician than if an RCD failed to protect from shock.
Thanks for the reply Andy, can you provide a link to where a faulty RCD has actually failed to protect from shock? Thanks.
AJJewsbury:Thanks for the reply Andy, can you provide a link to where a faulty RCD has actually failed to protect from shock?
I can't think of a publicised incident off the top of my head, but given that mots of us have found faulty RCDs at some point or other, it must be a finite risk.
Thanks for the reply Andy ?♂️
weirdbeard:Chris Pearson:
Provided that the CU is CE marked, BS certified, and from a reputable source, I find it difficult to see how the electrician could be held liable in the event that the SPD failed to provide the expected level of protectionThanks for the reply Chris, though i am unsure what contract you refer to?
The one between the sparks and the customer. Be aware that consumer protection legislation slips all sorts of terms into a contract between a business and a consumer such as goods have to be fit for purpose, as described, etc.
