Sparkingchip:
Is there any obligation to get a full EICR at every change of tenancy?
See the regulations, but in short: at the start of a new tenancy, the electrics must be inspected and tested, to no particualr standard or methodology.
wallywombat:Sparkingchip:
Is there any obligation to get a full EICR at every change of tenancy?See the regulations, but in short: at the start of a new tenancy, the electrics must be inspected and tested, to no particualr standard or methodology.
No it doesn't. It says:
(2) For the purposes of sub-paragraph (1)(b) “at regular intervals” means—
(a)at intervals of no more than 5 years; or
(b)where the most recent report under sub-paragraph (3)(a) requires such inspection and testing to be at intervals of less than 5 years, at the intervals specified in that report.
Nothing about re-testing on every change of tenant.
Sparkingchip:
no, if there is an existing (<5 years old) EICR to the 18th Ed., there is no requirement to get another one done at change of tenancy. BUT, as others have intimated it would be prudent to have a documented assessment done as to the state of the installation, not necessarily testing, but inspection, to see if any damage/alterations have occurred.
I note also that remedials done after an unsatisfactory EICR Must be done by a Qualified Person -
“qualified person” means a person competent to undertake the inspection and testing required under regulation 3(1) and any further investigative or remedial work in accordance with the electrical safety standards
So remedials can only be done by people "qualified" to produce an EICR, this would rule out NICEIC domestic installers such as myself, as we are not deemed competent by NICEIC as far as i am aware.
Edit: i have seen EICRs which state "5 years or at change of tenancy" in the box which would mean that a full re-test would then be required. Up to you :)
