3.—(1) A private landlord(7) who grants or intends to grant a specified tenancy must—
(a)ensure that the electrical safety standards are met during any period when the residential premises(8) are occupied under a specified tenancy;
(b)ensure every electrical installation in the residential premises is inspected and tested at regular intervals by a qualified person; and
(c)ensure the first inspection and testing is carried out—
(i)before the tenancy commences in relation to a new specified tenancy; or
(ii)by 1st April 2021 in relation to an existing specified tenancy.
davezawadi (David Stone):
I was speaking to an Estate Agent about letting a property last week, and she said, you need an EICR. True but she had no idea of what this was and had a tame "Electrician" available to carry it out for a high (my opinion) fee. I may do this and report back, because the results they get and I get may well not be the same! Just how much do you think a 2 bed house in good nick EICR should cost?
£109 including Maggie's share here.
Difficult to see how they make much if they do a proper job!
If that is the real failure rate of RCDs John, say 4% per year, they are not fit for purpose and EICRs are not the answer are they? Do the faulty ones test OK afterwards with the test button? If yes then there is work to do. Essential safety devices failing at 4% per year, that is monstrous.
0.6 to 0.8 per year over 140 devices = 0.4% - 0.6%
Chris Pearson:davezawadi (David Stone):
I was speaking to an Estate Agent about letting a property last week, and she said, you need an EICR. True but she had no idea of what this was and had a tame "Electrician" available to carry it out for a high (my opinion) fee. I may do this and report back, because the results they get and I get may well not be the same! Just how much do you think a 2 bed house in good nick EICR should cost?£109 including Maggie's share here.
I would think it would very depressing reading as specially as they then appear to subbing it out. Had a EICR sent to me to price putting right, have never seen anything so disappointing from a NICEIC approved firm. Under wiring systems for type and nature of the installation and external influences C2 with a description of (3x2.5 cables connected in 30a breaker) This is how it’s actually written. Supply protective device as BSEN 60947-3 Type 3 on the report. Only 6 circuits tested and all labelled unknown but somehow all have R1+R2 results. Both rings only serve 1 point and the lighting circuit has14 points but a R1+R2 of 0.03 The list is unless.
John Peckham:
Colin
Can you explain what you mean by that.
I find the biggest problem with EICRs is the person doing them!
That as well. Now landlords have to have an upto date EICR for new tenants there’s been a big demand. By 1st of April all will require an in date EICR so if there all given 5 years there’s going to a big peak every 5 years.
