Serge:
Hi, Andy. Thank You for reply. I read conditions.
can you tell how long does this approach take when creating an individual labeling for one project?
and how clear labeling is for the average user? or in your case, the user most often does not use the switches in main switchboard.
in Russia any fusebox look like this:
Sorry for cyrillic on a picture)
Small installation, not long using off-the-shelf electrician's labelling printer - one example: https://www.screwfix.com/p/brother-pte110-electricians-label-printing-machine/7795x
Various solutions available for larger installations, at least in the UK.
Unless it's a DIY job, in the UK there is no excuse for marking up by hand like that (but it does happen - even omitting labelling happens - but it shouldn't).
gkenyon:
It's worth noting, for anyone wishing to procure labels or labelling solutions, that there are relevant standards required for safety, other than BS 7671 (e.g. where BS 7671 does not have specific requirements). Some of these standards support applicable legislation.
Perhaps the most important for labelling on equipment, in addition to the requirements of BS 7671 are:
Strewth, that's £1292 worth of standards!
At home, I have made labels on matt white polyester sheets from Labelplanet. But that was guilding the lily - anybody else can make do with a Sharpie. ?
Those little symbols that come with Schneider (and other makes) consumer units don't really do it for me.
Serge:
Never mind the labels - it looks like there should be a market for modular blanks!
AJJewsbury:even omitting labelling happens
Ah, you mean the traditional British coloured dots labelling system?
White dots (a light colour) - lighting.
Blue dots (a water like colour) - immersion heater
Red dots (a hot colour) - for power - sockets or cooker (further sub divided by the red stripes just visible above the fuse terminal shield) - one thick for cooker, two (or more) thin for sockets.
Apparently well known for many years and had the benefit of being language independent (no need for anything different in Welsh speaking households for instance) and in most modest dwellings would uniqely identify every circuit. In larger homes were there might be more than one of each type of circuit you simply had to pull a fuse or two and see what stopped working - not too onerous (and probably more reliable that someone else's labels).
For those with non-standard fuse boxes without the coloured dots there was the "A" series alternative identification system - again language independent - 5A for lighting, 15A for the immersion and 30A for sockets/cooker (often sub-divided in the normal way by red stripes).
No, completely avoiding filling out anything at all on three-phase commercial final DBOs so no-one has a clue what feeds (or isolates) what !
Appalling when:
