Swimming pool 3 phase motor trips occasionally on earth leakage RCD
We have a new 4 kW 3 phase pump motor at the local pool which has a new variable speed drive unit attached and occasionally it trips out on the RCD which I assume is 30mAmp .  The connections are star inside the motor but not earthed which should have stopped it tripping.
We are not sure what to do, we could run the motor flat out and delta connect the windings possibly or some suggest disconnecting the RCD as the circuit is completely separate from normal wiring.  Would this option contravene any of our regs?
Parents
  • Thanks Andy,  I am having difficulty finding who makes type B so thought that the Siemens could be suitable.
Reply
Children
No Data
