New build fuseboard
Hi guys a couple of small questions i wondered if you would be able to help me out with.
1 In a new build would anyone have a issue with a fuseboard being in a upstairs cupboard ? as long as its still 1350/1450mm off the ground ?
2 I know main tails are meant to be max 3meters, if this was pushed to say 3.8 / 4 meters is this a major issue ?
Thank you for anyone taking the time to help and reply
Parents
  • If you were in Ireland, with new supplies, you are required by the DSO (DNO) to install a 63A type B in the exterior cubicle regardless of how far away the consumer unit is located! Strange these different requirements across a relatively small group of islands.  Sometimes in NI, the DNO will not connect unless main protective bonding is in place, even if the water service is plastic!
Reply
Children
No Data
