geoffsd:
We could desist from calling it a "Landlord electrical safety certificate" if it is an "Electrical installation condition report".
Therefore the regulations governing the issue of an (18th edition) EICR and the required actions following it apply.
The legislation doesn't actually refer to an EICR, it calls it "a report from the person conducting that inspection and test, which gives the results of the inspection and test and the date of the next inspection and test". It's really vague as to what inspection and testing should be carried out.
mapj1:
nothing precludes a metal box around the plastic one may not be the electrician's preferred solution, as it makes no new work for him/her but easy to show it now meets the regs.
Quite, stick a tin box over it.
Andy B.
Simon Barker:The legislation doesn't actually refer to an EICR, it calls it "a report from the person conducting that inspection and test, which gives the results of the inspection and test and the date of the next inspection and test". It's really vague as to what inspection and testing should be carried out.
Yes, I realise that but unless they stipulate a list of items to be inspected, then all there is is an EICR - presumably a full one with no limitations.
Whether knowingly or in ignorance, they have used the word 'report'.
There is no such thing as a landlord safety certificate.
geoffsd:Simon Barker:The legislation doesn't actually refer to an EICR, it calls it "a report from the person conducting that inspection and test, which gives the results of the inspection and test and the date of the next inspection and test". It's really vague as to what inspection and testing should be carried out.
Actually, reading the legislation again, not only does it not stipulate a list of items to be inspected, but it doesn't even say that the report has to be an inspection against "the electrical safety standards".
Seriously, it doesn't. Read Section 3 - (1) (a) to (c) in the most pedantic way you can think of, rather than assuming it means what it ought to say.
Simon Barker:Actually, reading the legislation again, not only does it not stipulate a list of items to be inspected, but it doesn't even say that the report has to be an inspection against "the electrical safety standards".
Does 3 - (1) (a) not say that?
"(a) ensure that the electrical safety standards are met during any period when the residential premises(2) are occupied under a specified tenancy;"
Then 3 - (3) (a) says a report must be obtained.
