davezawadi (David Stone):
This is up to the inspector. Whatever ESF or anyone else says maybe some justification, but it is still the inspector who decides. In many ways these "guides" are not a good idea, they are no replacement for inspection experience.
Couldn’t agree more David but these guides are often considered as chiselled in stone. They even feature in the 2391 Inspection and Testing exam.
perspicacious:
Wasn't there a post about http://www.legislation.gov.uk/uksi/2020/312/regulation/3/made requiring full compliance with the 18th with no deviations?
Well despite my best endeavours, Parliament doesn't quite understand the situation.
R3: "(4) Where a report under sub-paragraph (3)(a) indicates that a private landlord is or is potentially in breach of the duty under sub-paragraph (1)(a) and the report requires the private landlord to undertake further investigative or remedial work, the private landlord must ensure that further investigative or remedial work is carried out by a qualified person ..."
The breach seems to be clear - the installation does not comply with the 18th Edn.
The problem lies in the next bit. No EICR requires anybody to do anything; but let's assume that they meant "recommends". That still leaves C3s to be addressed; and if the local authority decides to take action, off we all go to the First-tier Tribunal.
What happens there? As it happens, I had an opportunity to speak to a judge of the Property Chamber of the FtT last week. In a case like this, the Tribunal would consist of a judge and a surveyor. The local authority would be legally represented, the landlord does not have to be. The Appellant (landlord) would have obtained a (favourable) expert report of his own. First of all, the lawyers might argue about the meaning of the word, "requires"; then they could spend the rest of the day debating the difference between a C1 or C2 on the one hand, and a C3 on the other and whether the latter imposes a requirement upon anybody to do anything.
Now we have a decision from the Tribunal, but it doesn't end there. It could be appealed to the Upper Tribunal where finally (almost finally ? ) the law would be settled.
I was told that the Property Chamber can be "quite adversarial".
So there we have it: a bean feast for the lawyers and expert engineers.
