ebee:
"I'm sure the manufacturers would recommend SPDs at every stage of distribution. "
Agreed AJJ
Slightly different scenario: intake into the garage/workshop, which is nearest to the street. Lighting and various socket circuits. It is most unlikely that any sensitive equipment will be plugged in there, so why have SPD at this point?
Switch fuse protecting distribution circuit to the house. Isn't the best place at the CU? If you are changing a CU (or installing from scratch) getting one with SPD already fitted seems to be a bit of a no-brainier.
