ebee:
I am struggling to envisage the layout. I think that what you are trying to achieve is possible.
Hopefully this is all on one circuit. Note that security lights and/or seperate sensors fall into two types - 1/ those that can be paralled up and / 2those that can not (although using relays you can get around that).
Also watch the total load that any sensor can switch.
It might prove more prudent to use a different system for security lighting control such as the GJD system using 12v detector heads (Opal) and one or more controllers such as Emerald/ Saphire etc.
If there is more than one circuit then interlinking via relays or better still radio links ("wireless" technology) is achieveable
Thanks Ebee - much appreciated - I uploaded a picture of the plan (if thats any use)
I will look into the other method suggested, however, I was wondering if in your opinion my original plan is acceptable if all else fails?
Basically multiple sensors connected to 1 connection point and acting individually to switch the feed to the lights on -
And yes mate just 1 circuit ( 1feed)
davezawadi (David Stone):
I suggest a programmable relay controller listening to all the switches (inputs) and power to the lights (outputs). You can then make any complex logical switching you like, and even if 2 switches are pushed at once, make the lights flash or respond to music. Then you provide a "random" function that confuses everyone occasionally on a timer, which changes all the logic to "now for something completely different" (Monty Python). You will only have very simple wiring, and the coding can be done at leisure, filling as much spare time as you have available!
There, I have achieved exactly what you want, and you have the opportunity to learn a new skill!
Thanks Dave - Appreciate your input mate, this sounds interesting - Would you be able to post a link of what you have in mind please - Had a quick Google and not quite sure what I'm looking for from the options that came up
Out of curiosity did you fully understand what my initial plan was and are you also suggesting that if 2 sensors are trigger at the same time the lights may flicker and behaving unpredictability?
Sparkingchip:
Just loop a three core and earth to every point and add switches or sensors as required between the live and switched live.
You can add a photo cell and timer configured to turn the lights on at as it gets dark and off at a certain time.
No coding required
Andy Betteridge
Or on on a winter morning and off as it gets light.
