gkenyon:
To be fair, if it meets BS EN 60998-series, and you separate the "choc-block" properly, then it should meet IP 2X or IPXXB. Of course, it will usually need a suitable enclosure to be fully compliant with BS 7671 for normal use.
Does that include the space under the floorboards when you poke one up through the hole in the ceiling?
