davezawadi (David Stone):
No, a VSD is a stand-alone device, it needs nothing else to operate except a motor. There is no assembly, and one can buy integrated motor-VSD packages which can just be connected or have a plug fitted.
That would then be a pluggable appliance and not the sort of thing that we'd have to worry about as far as BS 7671 is concerned ... the manufacturer would take all responsibility for the essential requirements of the Low Voltage Directive - or in the UK, Electrical Equipment (Safety) Regulations.
Since the VSD wouldn't do much without a motor, however (the right kind in terms of type and specification for that particular VSD), I'm not really sure it's a stand-alone device?
As for the GU10 lamp, the product standard is mechanical and says very little about the contents, the electronics, the brightness, the filament or LEDs, the colour temperature, the life. All this is simply about "level playing fields" and interchangeability and stifles innovation. Some standards are useful to all, for example, Screw Threads. However, this does not prevent other threads from being used if they are more suitable for some purpose, although this tends to single-source replacements. Cars are particularly bad at having bolts that are non-standard, particularly in the head size, because this suits automated assembly, but not repairs. BS7671 is becoming very prescriptive about items that really design decisions, usually on the grounds of alleged "safety" improvement, the real question is "exactly what degree of safety and risk" is reasonable and this needs to be exactly defined. If the same were applied to many human endeavors, most sport would never happen because people hurt themselves, some die, transport would be right out.
What about cookers? They fall foul of 131.1, in that they have hot parts which could cause burns.
I have to say that I thought that DZ had completely flipped here until I read 131.3.1 . "... during normal operation of ... minimal risk of burns ". So now your jobbing sparks has to prevent Mary Berry from burning her wrists when she takes a cake out of the oven! ??
lyledunn:gkenyon:
Yes, application of Regulation 419.3 is feasible, and then the question of a loop impedance disappears.Yes unless you want to argue that the prospective earth fault current should be assessed.
Loop impedance is only required for ADS.
The prospective fault current is required for a number of things ... ADS, if it applies in a particular arrangement, is only one possibility ...
