Exporting Tnc-s system
Goodmorning all
i have to put power to a wooden shed which is 50 metres away from the house. They will be no services in the shed
I will use SWA cable.
can I export the TNC-S system or I have to make it TT
regards
Paul
  • Or this model of garden office is a more extensive model for the Moreton-Shines at The Pines, Fox Grove Avenue, Ascot.
    1985 JULY 24567 Practical Householder Magazine SIT IN COMFORT | eBay
  • aargeitakis:
    Hi thanks for your reply
    it will be like an office !
    so not a lot of load, I use 6mm SWA.
    The problem with TT system it’s that you never you are sure, how satisfactory the earth will be
    Paul
    Yes, a total load not exceeding approx. 20 Amps will not cause too much Voltage drop.
  • Hi Tom,
    I`m thinking of the fact that the fuse in a "switched fused spur" would actually make it a new circuit just like a new consumer unit used as a sub main. A spur that is unfused from a ring or radial would make it merely an extension of a circuit. Daft innit? ?
  • Anyone can create and energise new circuits back to the consumer unit legally. However, to satisfy building control requirements they need to notify the council, and scheme members can do this very cheaply on a no inspection basis via their membership. Those of us who are independant of the system are supposed to notify building control direct, and they may want to send an inspector or not, depending what qualifications you have and what sort of day the chap at the other end is having.
    However, in the earlier version of Approved Doc  P     it was made very clear that Adding socket-outlets and fused spurs to an existing ring or radial circuit  Was not notifiable.
    Given that the subsequent versions are described as a relaxation,  it is clear that while BS7671 may consider a fuse as always starting a new circuit, for fused spurs from existing radials and rings, the authors of the building regs do not.
  • ebee:
    Hi Tom,
    Hello Ebee,
    Mmmmm? Haha, I'm confused now!!
    I would never consider you to be 'daft' at all!
    Keep up the good work!
    Tom
  • mapj1:
    Hello Mike,
    Ahhhh, I love 'ambiguity!!'
    Regards... Tom
