Induction Hob again
I hope that you don’t find me impudent but I am having difficulty finding an electrician to explain why they will not install the induction hob and double oven that we are looking to fit in our new kitchen.
We have chosen a hob 7.4 kW and oven 6.3 kW. The cooker radial circuit has 6mm2 cable with 40A MCB. The run is some 12 m. The house was built (converted) in 2002 and inspected last year (DPN18C). We cannot run an extra cable because the CU is separated from the kitchen without a horizontal floor or roof space and presumably runs the existing cable through the stud walls.
The kitchen fitting company electrician has visited but won’t carry out the work unless we sign an indemnity as it would invalidate our insurance and the appliance guarantee. He suggested instead two plug-in ovens which we could add to the ring main. I have contacted four other local electricians but they all use 13.7 kW means 59.7 A which means 10 mm cable and ignore my request to consider diversity.
Should I give up and accept the two oven solution or perhaps a gas oven?
Do you know of a way of finding someone who understands diversity?
Am I simply wrong?
  • AJJewsbury:
    and an induction wok wouldn't work without a specially shaped induction holder and a special wok
    How a wok would work was my other half's worry when we got an induction hob - she does like a stir-fry. But purchase of one induction compatible wok later (only real difference seemed to be a somewhat flattened bottom) - we found it worked perfectly well on the largest normal ring - certainly just as well as the dedicated 'wok burner' on her previous domestic gas hob.
    Flat-bottomed woks should be easy enough to come by.  I have had one for years.  They will work on almost any gas or electric ring.
