Terminating Twin and Earth - IET Engineering Communities (theiet.org)
mapj1:
On deliverable equipment I have been told off for using side cutters for stripping cores, as not the approved technique, but it all got a bit comical when the 'expert' technician was then called in to demonstrate correct use of the strippers, and then ended up using the side cutters on the thin stuff anyway.
I have a Facom stripper. Set the length and it trims and strips in one go. Highly recommended!
ebee:
Cheeswire method is ruf as badgers.
Knife blade resting on cpc is best but must be practised first by newbies.
A lorra those strippers are OK but it does reduce their life and they are expensive.
The newbies aren’t allowed to have or use sharp tools.
