Why was the old type 3/029 cable only rated at 7.8 amps ? I would have expected at least 10 or 12 amps based on cross sectional area, which is similar to modern 1.5mm. I would expect a rating of less than modern cables, but still at least 10 or 12 amps.
broadgage:
The Henley's Paper Insulated House Wire catalogue states that the 3/.029 Class YT cable has a SAFE CARRYING CAPACITY OF 7.8 amps. It will probably carry more than that for short periods. It may be something to do with the rubber insulation at the time.
Out of interest, the 7/.029 cable is rated at 18 Amps safe carrying capacity.
