EICR - Old Rewireable Fuse boards are these acceptable?
Hi,
I need verification that it is ok to keep old style Wylex rewireable fuse boards to pass the EICR. Initially the electrician said this was ok providing they have a cover for the fuses. However he has now changed his mind and saying they need to be replaced with a new consumer unit. Some of the homes do not have a cover on the fuse board and others have had the cover taken off so plug in mcb's can be accomodated. Is this still ok?
  • Zoomup:
    Kelly Marie Angel:
    I heard a story that a 5 amp lighting fuse in a wylex metal board ejected enough hot metal thru the little vent at the top of the fuse carrier   to create a short circuit that blew the DNOs 60  amp main fuse not just once but several times over the years  apparently there was a collection of dead 60 amp fuses on the floor of the understairs cupboard
    That may have happened with a metalclad Wylex consumer unit. Was the 60 Amp. fuse heavily loaded at the time, thus assisting the blowing?
    https://www.bing.com/videos/search?q=youtube+old++Wylex+metalclad+consumer+unit&docid=608044541727224394&mid=FD9A0F11EA66724B8365FD9A0F11EA66724B8365&view=detail&FORM=VIRE
    Hahaha! I LOVE my Wylex BUT... when I move, (I sold my house and was some 10 days' from exchanging when the new buyers pulled out BUT, hahaha... they came back, this past Monday and, hahaha, wanted to buy it AGAIN, I said NO as the price has increased SO, you lot will have to wait for when I move to see how I've fitted the change-over for the generator... sorry for the wait BUT, haha, it'll be worth it with lotsa photos' too), I will have a new / modern CCU WITH... an RCD!! PROMISE!!
    The thing is, if I'd let me son, before the new rules re; CCUs, came in... I would now have a new-ish PLASTIC fitted CCU in the under stairs cupboard ready to, perhaps, catch fire!
    The thing about RCDs is...
    1; You are supposed to reset them every six months', (who does that? Haha!)
    2; There is supposed to be something like a 6% failure rate.
    3; They can cause nuisance tripping... probably not a bad thing, really?
    My sister bought a 25 year old bungalow, recently. In her kitchen she was getting lots of ShOcKs from her electric / low level oven! The RCD didn't trip out as it wasn't shorting out the RCD. I removed the oven and found the earth wasn't, (hahaha, as you lot already was thinking this...), attached to the oven. No one believed my sister, that she was getting bad shocks off of it but I did. Anyways, this could be life threatening, to her, lucky she's ok.
    I respect the need for an RCD BUT, I'm ok, at the mo!!
    I did run, years' ago, a multi core PVC covered MICC cable, (spare core for a switch to operate the sheds outside light fitting, from inside of the house), but... I did fit an RCD for this so, I ain't that stupid, (BUT, others WILL disagree with this, haha)!
    Hope everyone has a nice relaxing bank holiday weekend!!!
    regards... Tom ?
    With regards to Chris P, too!
  • Hi zoom im not sure i think loading was fairly light only a few lamps and the TV  so maybe a few amps at most
  • Kelly Marie Angel:
    I have seen chunks of metal missing about the size of a mouse bite, above the rewireable fuse carriers in old Wylex metalclad consumer units where an arc has occurred. There was evidence of molten metal and heat damage, Perhaps fluorescent lights caused a high Voltage arc on the metalclad consumer unit when the 5 Amp. lighting fuse blew.
     I have just taken out an old Wylex consumer unit where the plastic covers are missing that went onto the main terminal screws. There is evidence of somebody having dropped a screwdriver or similar across the L and N terminals. The damage is obvious. I bet that that made  sparks and a bang.
