Jaymack:
A CU in a nursing home in Scotland had a fire in a storeroom, about 10 years ago, many old people were killed in the fire, thought attributable to an open fuseboard which did not contain the molten metal which set fire to cardboard boxes. I have seen the results of molten metal sparking on the metal edges at fuses, probably caused simply by pushing in the fuses onto a faulty circuit. Be wary of fuses, especially where no cover is fitted and where the Public is concerned. When all else fails use bloody great nails.
Jaymack
Yes, an electrical cause is always assumed when the real cause can not be identified. Nothing to do with somebody secretly smoking in the cupboard of course.
Tomgunn:wallywombat:
Why would you never fit an RCD?
Because I don't need them!
I can sympathize with Tom's position. I am not rushing to modernize my electrics indoors, but when I do get round to it, there will be modern CUs with RCDs, and possibly SPDs.
I am sure that Tom's installation is in good order as are his appliances. I do not onanistically inspect the flex every time I plug something in, but I do repair any damage that I see. Whether Mrs P would be bothered by ropey flex on her curling tongs, etc. is a different matter.
We are all grown-ups in here and not ordinary persons, so I think that Tom is entitled to do as he pleases; but what about customers' installations?
Kelly Marie Angel:
I heard a story that a 5 amp lighting fuse in a wylex metal board ejected enough hot metal thru the little vent at the top of the fuse carrier to create a short circuit that blew the DNOs 60 amp main fuse not just once but several times over the years apparently there was a collection of dead 60 amp fuses on the floor of the understairs cupboard
That may have happened with a metalclad Wylex consumer unit. Was the 60 Amp. fuse heavily loaded at the time, thus assisting the blowing?
https://www.bing.com/videos/search?q=youtube+old++Wylex+metalclad+consumer+unit&docid=608044541727224394&mid=FD9A0F11EA66724B8365FD9A0F11EA66724B8365&view=detail&FORM=VIRE
