broadgage:
Is this an old description of a vintage appliance appliance ? rather than modern ?
Cocus wood is a type of hardwood used for some electrical fittings before bakelite. Probable some low powered appliance with a wooden B22 plug so as to be used from a lamp socket.
Yes Broadgage, the description is from an old electrical catalogue of Ideal Labour Saving Domestic Electrical Appliances. The appliances include clothes' irons, water heaters that look like sauce pans, a toaster and kettles.
All appliances, which are mostly metal bodied seem to have just two core flexes. Perhaps that is why the insulated handles are very large and robust, to offer thermal and electric shock protection.
The plugs illustrated are small in the pictures, but appear to be a B.C. plug type that would fit into a lamp holder.
Would anyone like to guess at the power rating in Watts of the 240 Volt kettles?
Kelly Marie Angel:
Il take a wild stab in the dark and say 600 Watts at 240 volts AC or DC
Kelly Marie is spot on. 600 Watts is the answer. The kettle has a 2 pint capacity. It was called a model L55265. It was real highly polished copper in construction. A warning says:
"Be sure the kettle is filled before switching on the current, and on no circumstances completely empty while the element is still hot." The makers advise always leaving some water in the kettle to avoid the bottom burning out like a empty pan on a hot stove can.
The customer had to specify the Voltage rating of the kettle when ordering. The options were: 100/110 Volts. 200/220 Volts. 230/250 Volts. I bet that confused some customers. Or did the local electrical shop owner advise accordingly?
Fascinating.
