Kitchen in-line extractor fan.
Is there a 4 inch in-line extractor fan suitable for over a kitchen cooker, so that the fan unit is outside the kitchen and just a grille on the wall?
Edit. Add. I can't see any through inline filters suitable for 4 inch ducting online, just end fitting types used for hydroponics. Any ideas please?
  • Yes there are lots that are fine. Something like a UMD100 pro or most manufacturers do one that's suitable.
  • Check the extract rates though - kitchens tend to have at least 5' fans.
  • What type of kitchen cooker?
    Electric, gas, oil or solid fuel?
  • Nick Bennett:
    I am concerned about the build up of grease and crud inside the fan, as no filters are installed with basic inline fans as you would find in a cooker hood.
  • Sparkingchip:
    Small 4 ring, grille and oven electric.
  • You can get inline filters as well. Though not as easy for the home owner to access for cleaning. I would imagine it would become cost prohibitive at that point too.
  • Nick Bennett:
    Thanks. The ducting from the kitchen exits through a garage, so access to an in line filter before the fan will be easy.
  • Just be aware that a filter (even a clean one) will restrict the airflow significantly (along with the ducting and especially bends in the ducting) - I guess you'd be looking at achieving at least 30 litres/sec to comply with building regs (double that if it's not adjacent to the hob).
  • Perhaps a greased up, stalled fan in a brick wall, is not as much of risk as in a residential caravan; I was on the same site and remember 4 contractors from Beloit Walmsley in the U.K, they were in South Africa and all burned to death early one Sunday morning; they were on a contract for a new paper mill for Sappi. A fan in the kitchen, started a fire which spread very quickly. They were all "frozen" in position on the edge of their beds and the caravan was a burnt out shell..
    There should be an overheating/staled sensor in these fans with a working fire alarm- (mandatory but just for rented, domestic properties).
    Jaymack .
  • Jaymack:
    Jaymack .
    I tend to use Manrose fans as they are good quality. I hope that they contain a thermal cutout in the windings.
    The kitchen has a heat alarm, the other rooms smoke alarms......all interlinked.
    MF100S – MixFlo – 100mm commercial induct fan | Manrose
