Degree of Protection - Switchgears / MCCs/ Panels
What is the typical IP enclosure type used for Indoor switchgear / Outdoor switchgear Units?
What is the typical IP enclosure type used for Indoor switchgear / Outdoor switchgear Units? - In offshore Units?
  • Nick Parker:
    A start can be made at B.S. 7671 page 532 (Index) under Degree of Protection (IP).
    Section 416 is also useful.
  • Off shore units eh?  Might that include oil and gas rigs as found in the North Sea near to where I live? They are lit up at night like candles. So we have bad weather, storms, salt water, snow, flammable gasses and flammable oil.
    Hazardous Area Classification and Control of Ignition Sources (hse.gov.uk)
  • And there's more......
    HSE Offshore: Electrical and control systems
    Sometimes there can be problems even if the correct equipment is used.
    "In a recent incident on an offshore installation, there was an explosion in an open drains tank containing oily water. The tank contained an electric heater which was Ex certified. However, the sheath on the electric heating element had corroded, exposing the conductor. Although the incident is still being investigated, it is thought that this fault led to ignition of flammable material in the tank."
  • Well, I never knew that
    9. A small number of violent explosions of Ex luminaires have occurred offshore and it is suspected that hydrogen generated in the luminaires was the source of the flammable mixture rather than hydrocarbons released from the process plant. Excessive ingress of sea water can result in hydrogen generation by electrolysis. Tests carried out by the Health and Safety Laboratory (HSL) have demonstrated that electrolysis of sea water is possible, but is highly dependent on luminaire component geometry and ballast design. Hydrogen generation by electrolysis is equally possible with bi-pin or mono-pin designs.
  • IP ratings and farm life.
    Poor IP Ratings in Electrical Enclosures Leads to Devastation of the Wiring by Rodents and Mice - Bing video
  • Two familiar faces talking about IP ratings and IP equipment testing.
    IP66, IP67, IPx7, IP68 - Ingress protection of dust, water and testing of electrical equipment - YouTube
