2 electricity supplies to one building
Hello, I am a not an engineer but need some advice on uk wiring regulations please.
A national utility company is fitting a 32A charger in my garage for an electric vehicle.
The garage is detached from my house but there is an existing circuit from the house consumer unit to the garage for lighting and a power socket. The cable runs along a garden wall.
The new charger will have its own cable run from the same consumer unit in the house down to the garage.
My problem is that the engineer who came to do the installation refused to do it as he said the garage is a building in its own right and regulations do not allow 2 supplies to one building.
My question is: Do 2 wiring circuits from the same consumer unit constitute 2 supplies If the consumer unit is located in an adjacent building?
I would have thought that this was still a single supply and to have 2 supplies you need 2 separate meters with 2 consumer units which is not the case here but then, as I said, I’m no engineer.
Edit.....The engineer stated that the regulation related to avoiding the risk of a voltage between 2 different earths. To me this again only makes sense if you were talking about 2 totally different supplies from different meters and therefore possibly different sub stations etc.
  • Thank you BOD, I always wondered how some trucks manage to do 56.2 mph.
    So one truck overtakes another, that is a distance of, say 40 yards. At 0.2 mph, that takes about 7 minutes. OK, usually it is a bit less than that, but it goes to show how selfish some drivers are. That's both of them - the slower one for not reducing speed momentarily.
    Did we ever answer the original question?
    Rather sadly Chris, after seeing this tyre trick being done at a local tacho centre, the following week's job took me to a tyre depot so I measured the circumference of a used tyre compared to new and there was about 3% difference. Yet alone if the tyre has been re-cut...........
    Back to this one though, nobody has wanted to respond!
    BED (Vaccination tomorrow!)
    I can also see Authorised Supply Capacity being introduced as well as grid matched p/kWh for installs less than 69 kVA so that those who want to rapid charge their EV, pay for the privilege of National Grid keeping spinning reserve of the less efficient power stations just for their demand.
    Out of interest, how is France coping with domestic supplies limited to 30 A single-phase and EV charging?
