NICEIC EICR domestic report
Like many of us i have been doing a lot more EICR's than normal.  I was just going to order another pad of Domestic EICR forms (DPN18) when i remembered i have a pretty much unused pad of standard (non domestic) (IPN18) .   Is there any reason that i can't use the non-domestic for want of a better description for domestic.  What is the difference ?  I know the domestic are for up to 100amps.    It begs the question why are there 2 different ones if the IPN18 will be ok for both.
Gary
  • No problem, but you will have a load more "N/A" to fill in the inspection schedules as there are extra inspection bits for non domestic.
  • Has the schedule of inspections got any entries for bathrooms?
  • Looks like it doesn't specifically.  It has a section that says list all special locations and put results on a separate numbered page.
    Cheers
