M.K. Light Switches.
I have just been fitting some customer bought M.K. sockets and light switches; white Logic style.
I do not like the captive screws as they are initially very difficult to turn and you never quite know when they are fully tightened. I also do not like the very shallow light switch terminals that allow wires to come out, especially if twisted together. I ended up using a battery screwdriver to tighten the screws as my hands were starting to hurt.
Others' views please?
  • I also do not like the very shallow light switch terminals
    +1 for that! They're even worse with 7-strand cables than with solid ones - there's hardly enough depth to the terminals to contain a decent twist of the strands.
  • Zoomup:
    Twisted together??
  • Blencathra:
    Zoomup:
    Twisted together??
    www.bing.com/.../search
    Twisting the conductors together makes for a reliable mechanical and electrical connection rather than just pushing in two separate conductors. You know that they will not separate.
  • Are you talking about solid conductors, that vid looked like USA, twisting conductors before inserting into terminals makes testing & fault finding difficult, lost count of the times I have disconnected twisted solids and found a broken conductor
  • Shame to see what used to be the Rolls Royce of electrical accessories descend into rubbish, and over-priced rubbish at that. I have some original 1980s square edge MK stuff in my house - absolutely bombproof - large all-brass tunnel terminals and screws and a nice hard brown plastic back to house them in.
    I now refuse to fit MK anything - their Logic range is shyte and has resulted in many call outs for light switch failure. Their socket outlets are the same, absolute rubbish, along with those from Hager. Give me Contactum all day long.
  • Blencathra:
    I twisted the 1.0mm2 solid conductors on a three gang plate switch at the common terminals only. 1. Supply  L.+ link, 2. link to link, and lastly 3. link and L. loop out.
    2.5mm2 twisted at sockets are a no no for me.
    Blencathra:
    I’ll second that, thought that old practice of twisting cables together went out in the dark ages.
  • Zoomup:
    Blencathra:
    Twisting solids of any size is a no no for me, if they are terminated correctly there should be no problem pulling out, if theres a  few its Wago time, in fact if I found twisted solids on a job I untwist and reterminate
    Zoomup:
    We use MK a lot in commercial and industrial, I personally find the stuff great, admittedly the grid switch module connections could be a little deeper, but as for the the FCUs are great to install especially as all connections are in a nice straight line and you don’t have to keep twisting the accessory around to find which terminal is which, definitely wouldn’t be twisting cables together though, or using battery tools to tighten terminals.
  • definitely wouldn’t be twisting cables together though, or using battery tools to tighten terminals.
    A  battery operated driver with a clutch is fine for tightening screws. They are used in factory production lines all over the world.
