Zoomup:
10,145, 332.378 Giga Ohms.
Am I close?
It will more than likely be less!
Southampton to Auckland, New Zealand via Cape Town is roughly 17,000 km.
The earth is criss crossed with telecommunications cables which are steel wire armoured. So there should be continuity between any two countries that have those cables terminated there. As for its resistance, what is 17,000 km worth of armouring similar to that on steel wire protected underground cable. The armouring varies with location, ie near to land it is thicker for protection, less so for deep-sea.
Looking at my Australia to New Zealand Trans-Tasman Telegraph Cable samples,circa 1876, these vary from about 3/4 inch to 2 inches overall diameter. The inner conductor looks like 7/.029 or 7/.036 whilst the armouring varies up to about 6 mm diameter per strand.
Clive
perspicacious:
approx 80% of the total figure between two fart away points might be made up of the area around the local rod/plate/tapes etc
Probably best not to follow your nose here ebee!
BAD
Ahh Good, I wondered which one of you would spot that one!
Actually no sorry! typo
