Alan Capon:
Following on from BOD, it also means that the Device cannot be immediately reclosed, without the deliberate action of moving the operating lever to the “Off” position first. There are (were) a few other manufacturers that used the same method.
There is also an interesting issue with RCBOs on TT. If you fit a 10 way RCBO with an ordinary main switch, worst case, you can have up to 300mA of leakage before you get a trip. Your earth needs to be good enough for this, but ideally you want a time delayed main switch, especially if the RCBOs are single pole switching.
Alan.
Ideally upfront 100mA time delay RCD and then DP RCBO’s
And the reason for the R.C.D. tripping off when the oven is turned off is......?
perspicacious:
customer turned her oven OFF it tripped the R.C.D. to OFF
A little more detail required.
What does the oven thermostat switch?
Turning the oven off. How? By the temperature control switch? By the associated appliance switch. Is it part of a stand alone cooker?
BOD
First case. The temperature control switch did cause the oven to trip the R.C.D. to the tripped position. I witnessed this happen, but it did not trip the R.C.D. every time, just occasionally. I believe that the first appliance was a stand alone cooker, the second more recent one was just an oven on its own, and the temperature control switch caused the problem.
