Roger Bryant:
Petrol stations have various strict requirements regarding their electrical installations for obvious reasons. How will adding a MW size supply for a few high power chargers be dealt with, separation? Will earth leakage currents be a problem? If I remember correctly the reason the canopys are so high is to move the lighting into a different zone.
Yes, separation required for HV even before we get to the LV side of the transformer.
There is a supplement for the IET CoP for EV charging installations specifically covering this type of installation: https://shop.theiet.org/electric-vehicle-charging-installations-at-filling-stations
Sparkingchip:
Also my sat nav tells me when I am passing petrol stations and public EV charging points, again there’s a minimal number of public EV charging points.
I suspect that it's using a fairly dated database then, take a look at https://www.zap-map.com/live/ to get a map of charge points.
Currently there are about 40,000 charge points in 15,000 locations in the UK, compare with 8,400 petrol stations.
https://www.zap-map.com/statistics/#points
https://www.statista.com/statistics/312331/number-of-petrol-stations-in-the-united-kingdom-uk/
mapj1:
I have also often wondered if it would be better to re-invent motorail and keep cars on the move while charging them from the train.
Why move all those lumps of metal on the train? Just move the people and have a car share system at the stations like this:
https://www.mobility.ch/en/private-customers
Unfortunately it would need a similar mind set change to that required to move the Brit's into energy efficient appartments rather then unefficient my home is my castle detached houses.
