Safe Disconnection to Undertake Work.
Scene. An old farm building now used as a double glazing frame maker's workshop.
The supply comes from an old shed about 40 metres away, where the meter is. The old shed has some 70s/80s rusty M.E.M. isolators that feed several S.W.A. cables that exist the shed in many directions underground. I suspect that one feeds the main farmhouse, another a rented cottage and the others various farm buildings. There is no clear labelling of the isolators.
What is the best way to locate the frame maker's  building supply where I have to work?
Somewhere I have a circuit i/d set, if I can find it, but that will need access to the live parts and I do not wish to turn off the wrong isolator.
  • Short out the supply in the shed and see which fuse blows? Presumably, you cannot isolate one by one to see?
  • Zoomup:
    ... a double glazing frame maker ...
    Would have been a good one for What's My Line!
    I fear that good old trial and error may be required.
  • That was a slight joke, but you were too slow.
    The best way if you can get at the isolator tails is to put a load on in the shed and measure the load current there with a clamp meter. Go to the isolators and see which one has the same current. If none you may have a strange fault between, but it usually works.
    David
  • Has anyone tried one of those circuit tracers? The kind that you plug a "transmitter" in on the circuit you want to trace and then wave a "receiver" wand around likely supply point to see which gives the strongest signal? Never had a chance to play with one myself, but in theory sounds ideal for this kind of problem. I'm hoping the cables between the meter and switchfuses are insulated & sheathed so shouldn't screen out the trace signal (unlike perhaps the SWA armour).
  • I should have said that the cables are all in rusty metal trunking and pretty much inaccessible. I do not want to turn off trial and error style as I may cause problems for other people and the farm. I can not put a clamp meter on individual tails safely. To gain access to the supply cables I would have to turn off the M.E.M. isolators to get the doors open (interlocked).
    The supply I am working on is for three phase machines and I can not operate them as I am on my own tomorrow and am not familiar with them. The frame maker's building has a separate single phase supply to the three phase one that I am working on.
    Z..
  • davezawadi (David Stone):
    Yeh, but I still would not know which fuse had blown as they are hidden behind the M.E.M. isolator doors, and to get to them I would have to turn off to get the door open which may be a different circuit. I can not just turn everything off.
  • AJJewsbury:
    That's the thing Andy. I have one somewhere, but years ago I did not find the thing very reliable. Anyway I am working on a three phase circuit with no 13 Amp sockets, and I seem to recall that the kit has a 13 Amp plug-in transmitter in it. You then wave a yellow space gun thing about close to the M.C.B.s in a consumer unit and it flashes and bleeps if you find the right circuit. (Supposedly)
    David
    An improvement on this is a contactor and timer relay in a box with a 13 amp plug and socket. Insert plug into any working socket. Plug a suitable load such as a kettle into the socket. This will cycle on and off at say two second intervals, and the sub main feeding this pulsating load is easily located with a clamp meter. More reliable than a steady load.
  • My preferred solution would be to use a load of significant size, say 3kW or more & have a assistant turn this ON & OFF on command by using radios or mobile phones. It should then be easy enough to find this current at the supply end.
    I hear what you are saying about the cables being in trunking but it must be possible to remove the trunking lid?
    I can't see anyway of doing this without some (temporary) modification to the existing system
    You could always add a 13A socket short term/
  • AdrianWint:
    Yep, I reckon that I will have to rig up something like that. All cables and tails are in old rusty metal trunking at the meter position. I believe that the shed roof for some years leaked but has recently been repaired. I don't fancy really disturbing things too much as I don't know just what may break or fail to switch on again. Even removing the metal trunking lid maybe a hazard.
    Cue lecture from sensible safety conscious forum members. (You shouldn't be adding to a circuit that may be unsound). Yes, but I have confirmed that the earthing is o.k. and the supply is suitable to add a new small three phase board  for a new machine.
    Tin hat on!
