Maximum Demand / ENA / EV Help!
Hello all,
This evenings issue relates to an EV charger install.
The supply cut out is labelled 60/80 amp so I called the DNO and asked if this could be uprated to 100 amp.
They have sent me the ENA EV application form which asks for the Maximum Demand including the new equipment.
The problem I have is the existing circuits are:
32A - 7.2 kW shower
40A - 8.2 kW shower
32A - Ring main
32A - 7.9 kw cooker
6A - lighting
6A - lighting
6A - security
Additional 32A for EV charger
So even with diversity I'm way over 100A, obviously in reality the diversity calculations are not appropriate as the client has never blown the cut out.
The smaller shower is not currently in use although they want to replace it for another one, I have told them this may not be possible.
The EV charger will have load management but I still need to put a figure on the ENA form....
Help appriciated :)
  • Sparkingchip:
    There’s also an IET webinar available chaired by John Peckham with Mark Coles, Head of Technical Regulations at the IET and Graham Kenyon, Managing Director of G Kenyon Technology Ltd.
    https://electrical.theiet.org/bs-7671/faqs/webinar-questions-and-answers/electrical-diversity-and-load-curtailment-evc-webinar/
    Thanks for that link, a lot of questions re diversity.
    The answer for the maximum demand question would be data logging however due to seasonal changes not really possible.
    The reality is it is a educated estimate, which will become more accurate with experience!
    Being as the EV charger has load curtailment I will be adding demand however not excessive.  Also I intend to disconnect the unused shower so removing a 32A circuit and adding a 32A circuit.
  • Whats an ENA please
  • Kelly Marie Angel:
    Whats an ENA please
    Energy Networks Association, the UK body for gas and electricity transmission.
  • Thanks
  • The maximum demand situation is an absolute mess at the moment. I adopt the view taken by Jon Steward. My nett increase is zero as I only use EVSE with load curtailment.  I make my assessment of each situation based on the ENA cut out guidance and whether there are any combustible items stored within the immediate area. If I feel a safe install can proceed, I install and notify the DNO afterwards. I make it abundantly clear to the customer that the DNO may require upgrade not because of the additional EVSE but because their MD was theoretically already in excess of the supply capacity.
    I have been asked on occasion by the DNO (NIE) to advise if the load curtailment is fail safe, ie. that the charge current will be switched off in the event of any failure of the load monitoring circuit. I use the Myenergi Zappi for domestic installs so I simply sent the DNO their answer to that. I have had no response and that was at least 6months ago.
    We all must make sure our installations are safe but the burden of supply capacity has to be borne by the DNOs who can in turn deal directly with any agitation from their customers!
  • lyledunn:
    The 60A load limit as to whether the DNO is informened before or after is a nuisance, surely the majority of houses have a MD of more than 28A (32A to be added for the EVSE)??
    I will be pushing the Zappi as my prefered unit due to all the safety features being included although more maufacturers are going this way now.
  • This may be somewhat controversial but relates directly to the OP, maximum demand.
    It seems to me that the wrong person is being made to pay for the Government plan to switch to all Electric vehicles. The infrastructure simply cannot withstand the addition of domestic EV chargers, being a long-term large load. Load curtailment might work with a small number of Electric vehicles but simply cannot work if everyone has one! There is endless talk about "average load" and similar phrases (in the same way as "Green" generation BTW), but the electricity supply system is not anything to do with average loads, it is entirely dependant on the peak load being less than the supply capability at all times. The vehicle owner may be paying for a Zappi or whatever, which I presume are not cheap or free, but they are not paying the infrastructure cost at all, this will undoubtedly come on all consumers or the taxpayer at some point. This cost should come on the price of Electric cars now, including the huge "Carbon" cost of the infrastructure improvements and building much more nuclear generation very quickly ie. less than 10 years. A tax of 500% of the cost does not seem unreasonable, the estimated cost of going all-electric is currently £3 Trillion and rising every day that passes. Politics is as usual totally oblivious of economics, even if we rebuild everything it is doubtful if enough raw materials can be obtained, particularly copper and aluminium, remembering that aluminium refining needs immense amounts of electricity!
    If we all have to have heat pumps, which work in winter at -10C then the average consumer will be bankrupt, air exchange heat pumps have a COP of about 2 with -10 in and 50C out. The alternative will be the replacement of all heating in houses with full air conditioning, a pretty much impossible task. Is engineering impossibility and cost beyond the realm of Government? It seems that it is. Heat pumps everywhere will need another 100GW of power and distribution, ie 40 - 50 new nuclear plants (and that is only 2kW per domestic property!).
    Of course, I realise that electricity comes from political hot air, so there must be an infinite supply available! Maximum demand will go through the roof from these changes, this OP is trivial by comparison.
  • davezawadi (David Stone):
    Indeed!
    One wonders when the penny will drop.
    All this green agenda is wrongly pushed by 'climate alarmists'
    Pollution I get but CO2 i most certainly don't
  • Jon Steward:
    What about the London ULEZ extension?
    Some years ago I lived near to Hangar Lane Gyratory: about 100 yards inside the N. Circular. £12.50 a day would not have been funny.
    And what are tradesmen going to do? Sorry, luv, that'll be £12.50 extra for the ULEZ. ?
  • I have had a letter from Birmingham City Council to say that they had spotted my van on the new cameras and after the end of the month I will have to pay £8 per day to enter on top of the parking fees.
    If you are liable and you go up in the evening and do not leave until after midnight then you have to pay for two days, so £16 for a night out, as you would if you stay overnight with someone.
    There’s actually an eleven year age difference between the cars it applies to and vans, so it’s a lot more punitive for tradespeople in vans than people in cars.
    It may also make owning a “modern classic” car unrealistic and car buffs will be better off selling cars such as a Porsche and actually buying an older car that qualifies for an exemption.
