wallywombat:
The thing is, even you have a fully-trained, competent and experienced inspector, who can use their skill to, for example, determine that a shower is not RCD protected but is otherwise soundly installed, you still have a problem. Obviously this doesn't comply with the current regs, but how should it be coded? It has basic and fault protection. This is very subjective, and there is currently no right answer. So different inspectors could reasonably come to different codings for the same installation. So you either need informal guidelines like NAPIT codebreakers, or statutory minimums.
Could NAPIT codebreakers actually be the cause of some bad coding. C2 for cables less than 50mm in prescribed zones not protected by an RCD basically renders all pre 17th installations as unsatisfactory?
Sparkingchip:
How do you prevent someone from knocking a nail into the wall to hang a picture in a rented home?
Are any pre 17th Edition electrical installations in rented homes satisfactory?
What is the benchmark?
Do lighting circuits needs a circuit protective conductor?
Depends if you go NAPIT or NICEIC, both say different.
Landlords of privately rented accommodation must:
wallywombat:
And, how many of us take a shower cover off to check earthing and tightness of the terminals. Many electric shower units have no exposed conductive parts, and the water outlet fitting is made of nylon so a loop test can not be undertaken easily.
Sparkingchip:
Quite.
The minimum standards for electrical installations in rented homes should be written down so everyone knows what is deemed acceptable, allowing them to determine what is unacceptable.
“If you fail to plan, you are planning to fail!”
Benjamin Franklin
My mate drinks with im down the Nags Head. So it woz im wot scrawled that on the bog wall just under "if you are reading this then you are...................."
z.
