davezawadi (David Stone):
Simon, we do not usually refer to kK, and the temperature is not kelvins, it is Kelvin, say 300 K. The degrees are Centigrade degrees, just that the zero is moved, for very low temperatures, and certain thermodynamic points which depend on absolute temperature. 0K is about -273 degrees C.
The National Physical Laboratory would disagree with you on that one, as would the US National Institute of Standards and Technology (NIST). The unit of temperature is kelvin, and for current is ampere. And the same for all the derived units (hertz, newton, pascal, joule, watt, and so on).
https://www.npl.co.uk/si-units
https://physics.nist.gov/cuu/Units/units.html
But, oddly, temperature can also be in degrees Celsius, with a capital C.
Simon Barker:davezawadi (David Stone):
Simon, we do not usually refer to kK, and the temperature is not kelvins, it is Kelvin, say 300 K. The degrees are Centigrade degrees, just that the zero is moved, for very low temperatures, and certain thermodynamic points which depend on absolute temperature. 0K is about -273 degrees C.The National Physical Laboratory would disagree with you on that one, as would the US National Institute of Standards and Technology (NIST). The unit of temperature is kelvin, and for current is ampere. And the same for all the derived units (hertz, newton, pascal, joule, watt, and so on).
So even the supposedly learned, pointed headed, white coated people can get things wrong.
Simon Barker:
Strange that the base unit for mass is the kilogram and not gram!
