mapj1:
.. lights rated at 160 volts, 75 watts. .. three strings to total about 75 watts.
The purpose of these is left to the reader.
Well all 3 in series would suit a radial display if you had a split phase supply (480 between "phases") or just between normal phases if you wanted the lights to last longer.
Or maybe you used them in series with some other load like a florry tube, or to charge batteries perhaps, or to provide a light dimming function. There are a number of options. Not least is that for some odd reason you had a 160V supply.?
Yes, used in series with a 4 foot 40 watt fluorescent tube. A local shop had a number of twin four foot fluorescent fittings that contained no chokes. Each tube was in series with a special bulb of 160 volts 75 watts.
They wanted to connect Christmas lights to these fittings instead of the special bulbs, so I made several strings of Christmas lights each of which was 160 volts at 72 watts, close enough and worked fine.
AFAIK the special ballast lamps are no longer available. Philips listed them into the 1980s I think.
mapj1:
..had a call from a man ..his socket didn't work! It didn't, as the carer had plugged an extension lead in to run a heater ..
His father had bought the house in 1934 and had electricity put in and a socket.
Assuming it was not a 13A plug being forced into a round pin socket - just about possible with some designs- my money is on the socket being on a 5A fused radial, and therefore not man enough for the heater.
Call me cynical, but my take on this was that there never was any wiring, just a pretence. With plenty of bedding, who needs heating? Perhaps Oxford had gone all luxurious in Mike's undergraduate days? ?
mapj1:
It was a 13A socket as someone in the distance past had changed the 15A to 13A but naturally left the lead cable in.
Lighting was lead and the whole place had just a 15a MEM switchfuse for the socket and a couple of 'porcelain ceiling roses' with 5a fusewire into lead 1.044 twin cable for lighting.
ebee:
Kids today have about as much ability to put a plug on a flex as Mr Bean
