We have a motorhome that had a dual fuel stove (3x gas & 1x electric ring and electric fan oven) and the 13A socket has been installed on the wall below the oven section of the stove. The sides of the stove go all the way to the floor. Because it's got a gas grill and oven there is vent at the rear of the hob to allow excess heat to escape from the rear of the stove.
The socket is 100mm above the floor but the floor is vented to the outside to comply with the gas regulations so I think the height shouldn't be an issue.
The issue is when a pan boils over the liquid can get down the back of the stove and onto the 13A socket which trips the RCD. The manufacture claims the motorhome has passed all the relevant electrical checks but to me this just doesn't seam correct.
Is there a regulations / compliance document that would cover this installation and, if not compliant, could be used to encourage the manufacturer to perform a modification to make the installation compliant?
