Extent of Electrical Installation Covered by this Report.
A potential customer has just handed me a copy of an E.I.C.R. The reason given for the  extent of the report is:
“Consumer Unit Only.”
The report seems to be genuine regarding the information provided. The reason for it is that the house is let to a tenant. A basic Test Schedule is included.
  • I went to this job today. I have re-read the original E.I.C.R. One thing that stood out today was the old cutout main fuse. The carrier is clearly marked 60 Amp. It was sealed but not fully home. I can't explain that. The fuse inside was indeed a 60 Amp fuse. The E.I.C.R. states it as being an 80 Amp fuse. Why?
  • Because the original Inspector made it up.
    Probably as he didnt want to remove the fuse, and be liable for a fine from the DNO.
    He should have put ‘LIM’ in the box.
  • Or the fuse had been changed since the EICR was compiled…
    Or simple human error… (mis-read hand written site notes when back at the office)
  • I believe that the 60 Amp fuse was the original from Noah's time. Very old and original. Complying with a 1953 B.S. printed on it. The seal was wire with a circular lead seal.
    I can't imagine anyone putting an 80 Amp fuse into a 60 Amp carrier where the carrier is clearly marked by the manufacturer as being rated at 60 Amps.
    Another point of interest. The old consumer unit was a Crabtree make. It had a 100mA main switch and M.C.B.s. It is very good quality, but a first for me. The surround/mounting frame was wooden. I have seen wooden framed Wylex boards but not wooden framed Crabtree boards.
  • Zoomup:
    An 80 A fuse might not even fit, depending upon the type.
  • Update. The building surveyor's electrician charges £145.00 per consumer unit, and takes about 2 hours according to the nice lady at the office today. Presumably this is for the limited “consumer unit only” type E.I.C.R.
  • Zoomup:
    Was a paper seal from the Supplier applied after you had determined this ?.
    Jaymack
  • The extent box is rather more than that Andy. If the installation is much larger then it is used to show from what DB onwards is being reported. In a bigger install, say a hospital which has a number of buildings, then it is perfectly reasonable to inspect one of them, or perhaps just a part after an incident, say a fire. It is not to look at a single item! This is a deliberate abuse of the EICR system, as one was advised from the "old" 2391.
  • I was asked to do an EICR for a customer a few weeks ago on the extension wiring only as the original installer had not provided any certification 6 or 7 years ago. This had been suggested by the council so that he could get it signed off.  This comprised of 3 circuits from an existing DB.  The extent box is useful sometimes.
    Gary
  • Yes Gary, just as you say, but not just the CU, it says virtually nothing useful!
