Crimps on Aluminium twin and earth cable.
I don't like crimps on twin and earth,  but this definitely wasn't a good idea!
  • I have deleted one picture, it made it too easy to spot the issue because I had zoomed in on something  and you need to use your electricians visual inspection skills.
  • At least the wooden frame didn't catch fire. A 2.5mm2 cable protected by a 30/32 Amp device. So that is what can happen. Was it a ring final?
  • Keep looking at the pictures.
  • Zoomup:
    I suspect that the outcome would be similar with a 20 amp fuse.
    I am not a fan of crimped connections. I appreciate that a good crimp tool, good materials and a careful operator CAN make reliable connections, but in practice they seem unreliable.
    When working as a building maintenance engineer, a significant part of my work was locating and rectifying faults caused by defective crimped connections.
  • Agreed, but there is a very specific problem that is rarely encountered, you need to look at the photos again.
  • Is the top hole of the red 30 Amp insulating shield heat damaged. Did the fuse carrier overheat and transfer heat upwards to the crimped joint, thus assisting its demise? I assume that the heat damage is caused mainly by the bad crimp, a heavy load,  and I2R heating.
    O.K. The old red L. was heat damaged. Probably due to  bad stripping of the cable. The L. was renewed with a short section of brown 2.5mm2. It appears that  L. may have overheated and migrated into a C.P.C.
  • Looks like it could be aluminium cable going by the cpc in view
