Requirements for an electrical design & the EIC form signature
I’ve read the interesting post at Who is the electrical installation designer? - IET Engineering Communities (theiet.org) on “Who is the electrical installation designer?” but my thought is somewhat different else I would have tagged onto that thread.
I’ve also read the posts at  Electrical Design Courses & Regulations Recommendations (London, UK) - IET Engineering Communities (theiet.org) regarding the training and competence needed for electrical design and having been involved in electrical works for a considerable period am familiar with the significance of this role. Indeed, when I ask for new works of a small size direct to an electrical contractor I always ensure that the wording of taking on board design liability is included, this such that they are clear and can also charge for that work and its responsibility.  Larger works may be by an electrical designer such as a consultant.
Considering that the EIC has an entry for design where it states:
FOR DESIGN
I/We being the person(s) responsible for the design of the electrical installation (as indicated by my/our signatures below), particulars of which are described above, having exercised reasonable skill and care when carrying out the design and additionally where this certificate applies to an add1t1on or alteration, the safety of the existing installation is not impaired, hereby CERTIFY that the design work for which I/we have been responsible is to the best of my/our knowledge and belief in accordance with BS 7671 :2018, amended to ….. except for the departures, if any, detailed .as follows:
What extent of information do readers consider to constitute an electrical design ?   Much of my reference information is in my office and I’ve not been there for 18 months so I thought I’d ask others what they considered to be the minimum information as to what comprises an electrical design for an installation has rather than trawl through other sources.  I thought it would be an interesting discussion point as well.
Paul.
  • only a consultants plan showing locations of lights, heaters etc. with a statement that it must comply with the IEE Wiring Regulations (yes it said IEE and not IET) so it was being left to the contractor to design the electrical installation itself.
    A pretty common state of affairs I would have thought. Probably comparable to a domestic customer simply asking for ‘an extra socket there please’ - after all they're not bothered if it's supplied from a spur, or the ring extended, or from a new circuit (except where it significantly affects the price) - they're happy to let their electrician use their professional judgement. Likewise designs are often not written down - after all if the design is straight forward and the designer and the installer are one and the same, communication can be implicit.
    But, I bet they still charged the client 12% of the electrical works for the design when really it was just an “architect's impression”………………………………………………….
    BOD (a little hyped up this evening having been a passenger in a 718 Spyder driven “enthusiastically”!)
  • Paul4A:
    Surely a design has got to include at least the cable sizes, the circuit protection details by way of RCBO sizes and types, the containment details as sizes should also have been worked out etc.
    I would say so; but people who advise on curtains, carpets, and cushions call themselves designers.
    Who is the designer in the customer's opinion? Daughter hasn't a clue. Her extension/annexe will include the swimming pool heater, the new bit, and in all probability an EVCP. So do you re-route the supply to the new bit, which will use the majority of the leccy, and distribute to the existing CU (or in fact it's replacement, which is overdue) or do you supply everything from the existing CU?
    I'd have 3-phase put into the new bit - as far as I can see, there is 3-phase aerial cable to the last pole before the house. To me it's a no-brainer. But it's all Greek to madam, and I doubt that her new sparks could cope. So there we have it, design by rule of thumb.
    Sorry, I'm tired and grumpy this evening. No Porsche for me, just driving a R-R enthusiastically on country roads aiming to avoid the traffic.
  • Paul4A:
    I meant for this to discuss the practical requirements or outcomes that made an electrical design which would fulfil the design requirements for recording on an EIC.   There is a requirement for competence and legal responsibilities over design, having a design liability.
    As an example that got me thinking about this, I could give chapter and verse on a recent experience whereby an electrical contractor confusingly completed an NICEIC EIC to say that both they and an architect designed it and a second contractor I asked to confirm the also poor installation indicated that the M&E consultant designed it.   In my opinion, there was no electrical design at tender stage, only a consultants plan showing locations of lights, heaters etc. with a statement that it must comply with the IEE Wiring Regulations (yes it said IEE and not IET) so it was being left to the contractor to design the electrical installation itself.
    Paul
    See Section 132 of 7671
  • Thanks Lyle, reminding me that I should have looked in the Regulations first.  For reference that section indicates:
    132 DESIGN
    132.1 General
    The electrical installation shall be designed by one or more skilled persons to provide for:
    (i) the protection of persons, livestock and property in accordance with Section 131
    (ii) the proper functioning of the electrical installation for the intended use.
    The information required as a basis for design is stated in Regulations 132.2 to 5.
    The requirements with which the design shall comply are stated in Regulations 132.6 to 16.
    The titles of those requirement regulation paragraphs are:
    132.6 Cross-sectional area of conductors
    132.7 Type of wiring and method of installation
    132.8 Protective equipment
    132.9 Emergency control
    132.10 Disconnecting devices
    132.11 Prevention of mutual detrimental influence
    132.12 Accessibility of electrical equipment
    132.13 Documentation for the electrical installation
    132.14 Protective devices and switches
    132.15 Isolation and switching
    132.16 Additions and alterations to an installation
    There's obviously detail to each of those paragraph sections in the Regulations themselves.
    Paul
