RCD tests and aged mother in-laws
This is a grumble, of minimal technical content, so  feel free to skip it.
MIL lives in a static caravan type thing, with a TT supply, earth rod beneath and RCDs inside and out. So far so good.  She is not that hot on technical stuff, and the external RCD is in a shared meter box  about 10m from the caravan , to reach it involves a squeeze through a hole in a hedge and skip over a low chain link fence.  I did buy her a key, but it is not exactly readily accessible,
Having bought a wonder cure earth mat to fit below the bed to aid the aches and pains of age ( I roll my eyes but say nothing) the instructions told her to ‘check the socket is earthed before use’
So she ticks the box online and buys the tester that is offered to go with it at an exorbitant fee. Its one of those with 3 lights, and a feature new to me, a ‘test RCD’  button.
So she plugs in the tester, and the right pattern of lights come on, but being easily confused she is not sure if that is all she has to do,  so presses the "RCD test" button just in case. Cue lights out, mild panic and beeping from the answer phone.
So I get a call from her mobile (in itself remarkable - its normally flat and use of the land line is more common) and drive out on a rescue mission at about 10PM.
On the plus side, in nearly 10 years of living there, it seems that is the first time the RCD in the meter box has been tested except when I did it when she moved in.
The hard part was explaining what the test button does actually  test, and reassuring her that a ‘pass’ is when the power goes off. And not to do it again when it is dark and I am  far away.
I now await the complaint that the earth mat under the bed is in some way broken.
  • Priceless ?
  • I once spent an hour trying to convince someone my own age a few years back that his loss of picture on his telly was not down to the fuse in his plugtop. A 5amp fuse was only letting 5 amps in so the picture would come if he put a 13 amp fuse in its place. Trying to explain that the TV was either On or Off depending on whether or not the fuse was intact was a nightmare
  • I can see the logic. You haven't said whether or not a 13 A fuse had been tried successfully. Nominally, a 5 A fuse allows up to 5 A to flow, but no more. It seems a bit unlikely, but if the TV did draw more current because of some fault (perhaps the cat had chewed the cable) a 13 A fuse might allow it to function, which would support the old bloke's analysis.
    I don't expect that modern TVs have high inrush currents, but because they don't have to warm up, perhaps they do? ?
  • The RCD tester probably thumped it with several hundred milliamperes to wake it up.
  • So the moral of this story is … don't get married????
  • One test in 10 years is probably typical of most households
    David
