T.V. Wiring.
How do I connect a second t.v. to a sky box to watch different programmes to the first t.v. please?
    By paying for this facility……..
    BOD
  • perspicacious:
    BOD
    Is there a wet string interconnection then?
    Only if you're damp enough to pay for the additional service……………
    BOD
  • Depends on the sky box. For SkyQ HDMI splitter and then use a HDMI sender over CAT6.
  • You generally need a box for each TV, with each box wired back to the LNB on the dish (assuming it's a Quad LNB or similar).  You can't just split the co-ax feed for satellite as there is some switching sent back up the cable from the box to the LNB to tell it which polarisation and signal band to send depending on your selected channel.  That needs to be done individually per box.
    It looks like they have some fancy wireless option available with SkyQ - This link may help:
  • Just seen the different channel bit, tell them to get SkyQ multiroom.
  • perspicacious:
    BOD
    No problem there then. The customer has large liquid assets.
  • Wireless t.v?
    This subway passenger decided that the best way to travel is with a her television on her head, interesting
    It appears to be £12 a month in addition to the existing monthly payment.
    BOD
  • perspicacious:
    BOD
    Good value.
