Hi
I have seen different methods of doing this. The neutrals are joined in a connector block in the switch box and the same for the earths. However one some occasions I have seen the live feeds into the switch and the live feed out to the next switch looped at the switch terminals. On other occasions I have seen the aforementioned live feeds joined in a connector block in the switch box and a single wire from this to the switch terminal. Both have the same outcome but the latter is unnecessary and adds another connector block to an already crowded switch box. The switch terminals are usually 10a rated anyway so joining at the switch terminals should be ok in my opinion. What is your method of choice?
