Onsite-substations
Hi,
Just wondering for onsite-substations are they property of the DNO or the site owner?
How would  the supplies be worked out? For example, will the DNO provide a supply point coming out of the substation with a fuse cut-out and meter ready to be connected to a panel board etc?
Thanks.
J
    the DNO assume that you always want them to do this for you, and charge handsomely for doing so, i found that they are difficult to deal with, and that there are many other companies out there who are both cheaper, and are far easier to deal with.
  • You should also check how easy your chosen supplier has access to spares. DNO transformers of 315, 500 and 1000KVA should all be off-the-shelf items, albeit usually at 440V nominal.
    Alan.
  • ours are all 1000KVA but the tap changers set at their lowest, and are all Schneider units.
  • grubbym:
    well, we use another company, and, to be fair, are a pleasure to deal with, and have got us out of sticky situations in the past
  • Thanks for all your responses guys.
    Also why don't they make cut-outs for greater than 600A supply. For example, this scenario where it can be upto 800A. I am assuming the blue line is the service cable coming into the customers property.  How will the meter for the energy supplier get connected ?
    Or as mentioned by others above, the metering will be done in the DNO owned/controlled bit?
    Thanks.
  • there will be a metering cabinet, with a CT meter, looking fairly ordinary, but instead of the supply passing through it, it uses a current transformer. The meter will be accessible to you, but the CTs wont be
  • So the metering cabinet is inside the substation or outside ?
  • it will be in the low voltage switchroom, ie, your premises
  • Ahh I get you now. So it would be something like this: the service cable (blue line) coming into the LV switch room ( either brick built or GRP ) through a CT and going into lets say a big panel board? Thanks Johno12345.
  • service cable into your panel board onto an ACB or similar, the CTs being somewhere inaccessible upstream, fed to the meter by an armoured cable.
