I am looking at how best to terminate EV ultra cable for a EV charger at the consumer unit end.
The data cable for EV ultra has insulation rated at the same voltage as the power cables and therefore can be run inside the consumer unit. If there is space it would be quite tidy to actually mount the CT clamp inside the consumer unit as well.
I have seen some on you tube do this with some heat shrink to give extra protection and wagos to make connection between the EV ultra and the CT clamp cable. I would probably go for a crimp connector as myenergie at least seem to feel spring connectors are unreliable for data.
Just wondering if others view this as an acceptable/good solution
