Underground Cable Tracing.
An P.V.C./P.V.C.  cable is run in steel conduit underground from a farm barn to another location. It may run underground to some nearby concrete slabs previously used as a base for wooden sheds, or it may run for about 80 metres to some distant  derelict outbuildings.
I am not too familiar with all of the types of underground cable tracers available.
Which would be the best type of cable tracer to use to determine its run? There may be other buried metal to confuse some tracers. Will a signal injected into the cable be able to be detected by a cable tracer as the cable in inside steel conduit?
The cable is currently dead.
Thanks,
Parents
  • If Voodoo works use that too, no shame in using what works, even to a small degree
Reply
Children
No Data
